Whenever a nut is subject to rotation, it is required to have a drilled bolt, castellated nut, and cotter key. In the top photo you can see that the proper bolt/nut combination is correctly used on the forward rudder cable link attachment, but not on the aft one. Similarly, in the bottom photo the nut on the control column, which uses a brass insert as a bushing, requires a castellated nut. If a bolt is used through a rod end bearing, the use of a fiber locknut is approved, as the bushing in the rod end bearing rotates instead of the bolt.
One Piece at a Time
Les Krumel invested 22 years building his award-winning Thorp T-18.
Making Peace with the Jabiru Engine
Dave Prizio - 2
Keep it cool: That’s the secret to success with the Jabiru engine, which will reward your efforts by being a simple, powerful and smooth-running powerplant. Dave Prizio offers some suggestions for Jabiru care.
