Join us for this detailed discussion of the new Rotax 916-powered Carbon Cub UL with CubCrafters’ Brad Damm. He explains the reasons behind adopting the four-cylinder turbo Rotax into the Carbon Cub airframe, talks about the ongoing development process and gives some insight into the next steps for the airplane, which will be offered as both a production-line LSA as well as an Experimental/Amateur-Built airplane. Plus: Look for our flight review video coming soon!
Alternative Energies
Dean Sigler - 0
The Grand Unified Airplane: Is it possible to extract energy from the act of flight itself? By Dean Sigler.
Dan’s World
Columnist and RV builder Dan Checkoway advocates keeping it simple so that you can actually afford to fuel and fly your homebuilt aircraft. He claims many builders buy into the hype about the latest and greatest equipment must-haves, and then complain about the price at the pump.
Around the Patch
Recent casualties in the kit-aircraft universe including AirlinkTECH, Pillar Point Avionics and Superior Air Parts reduce services available to builders and potentially eliminate some healthy competiton. By Marc Cook.
Dare To Be Bare
After checking with a variety of aluminum polishing aficionados, author Bob Fritz came up with a winning combination for maintaining the shine on metal airplanes. He details not only which products to use, but also how to use them for maximum effectiveness with minimal elbow grease.
