This rudder stop on a Kitfox was barely touching the rudder horns and was close to imminent failure, which could have caused binding of the rudder, most likely at the most inopportune time. Welded tabs used as control stops on tube-and-fabric aircraft such as these are fine, but they usually require some fine-tuning once the aircraft is completely assembled.
Learning To Identify Solid Rivets
Nearly every homebuilt aircraft kit has at least a few solid rivets helping to...
Bearhawk LSA
Jared Yates - 0
Simple and light—very light: The Bearhawk LSA is the latest addition to the Bearhawk family, the culmination of decades of design experience.
