It is common practice in many amateur-built engine installations, from Rotaxes to Lycomings, to use K&N filters. They do a wonderful job of filtering the air, and they are reusable. However, they only are able to perform correctly if they are properly cared for. They should be cleaned annually at a minimum with K&N filter cleaner and then lightly oiled with K&N filter oil. Without the oil, which leaves a slight pink color on the filter, they will not filter properly. The one in the photo above was not oiled.
Flying: Part Science, Part Artform
Many years ago, I had a position in the training department of my regional...
Product Review: Garmin GI 275 EFIS
This full-featured, full-priced certified EFIS is impressive but might not be ideal for homebuilts.
Aero ‘lectrics
Proper sizing and selection of the wire that goes into an aircraft can have a profound effect on the efficacy of the installation.
