In the tightly cowled engine compartment of an E/A-B aircraft, exhaust systems can do unseen damage over time unless care is taken to protect various components. In this case, the intake tube hose on a Lycoming engine shows severe signs of overheating due to its proximity to the exhaust system. When touched, it was very brittle and started flaking apart. Left unchecked, it will eventually cause an intake leak and the cylinder will run lean.
An Aussie Take on Throttle-Body Fuel Injection
Steve Ells - 2
Rotec has a new throttle-body injection system that's worth looking at.
Aero ‘lectrics
Jim Weir delves into the world of barrier strips, wire markers, resettable fuses, nylon connector usage, dyeing and inrush current limiters.
