This fuel line leak was noted at the exit of a fuel pump on an RV-14. It is right above the exhaust pipe! One needs to be careful when having hoses fabricated by non-aircraft supply houses that the flares and fittings are made for 37.5-degree AN-type fittings, as opposed to the standard 45-degree automotive flare. This nut was checked and was tight, so it was a mismatch in the flare or a cracked flare.
Error Chain
CozyJet dead-stick. Losing an engine was the least of the problems. It was a brake fire that almost destroyed this one-of-a-kind homebuilt.
Metal Working 11-part Series
Now the exceedingly popular and extraordinarily useful 11-part Build YourSkills: Metal Series is available as a single PDF. This must-have additionto your library was written by RV-7 builder Dan Checkoway and carefullyillustrated for first-time metal-workers and old hands alike. Mosteverything you need to now, from material handling and cutting to deburring,drilling and riveting is in this series.
Archive: September 1997
The rakish, T-tail Ban-Bi homebuilt was on our September 1997 cover, teased as “French...
