If you’ve ever seen some of the high-speed photography taken of aircraft engine cylinders during operation, you realize how much they shake—much like a wet dog trying to dry off! Anything and everything that is attached to the engine needs to be checked regularly for proper tightness. One common problem area is the screws holding the baffling to the engine. Both of these screws were found to be missing on the same aircraft.
Inside KITPLANES: How We Do Aerial Photography
Marc Cook explains the nuts-and-bolts of how we achieve the aerial photography that appears in the magazine, and offers a few pointers on how to capture your own plane in flight.
Mel Asberry - 0
Private pilots flying LSAs, aircraft registration, prop strikes, E/AB to ELSA, N-number location.
Analysis Tools
David Paule - 0
We don't use slide rules anymore. Back in the day, they were handy...
Where’s the Best Place To Build?
You and your airplane kit deserve a comfortable workshop area for the many days...
