uAvionix tailBeaconX
An all-in-one taillight and Mode S transponder.
uAvionix tailBeacon XuAvionix made a name for itself with the innovative skyBeacon and tailBeacon ADS-B Out solutions‭. ‬These 978‭ ‬MHz UAT devices‭, ‬intended to replace a wingtip strobe and taillight‭, ‬respectively‭, ‬proved popular for owners wanting a cost-effective way to get ADS-B compliance without having to‭ ‬invest in a new transponder or install other equipment inside the aircraft‭. ‬They have been especially popular among certified aircraft because of their ease of installation‭, ‬though they have penetrated the Experimental market as well‭. ‬A good product easily‭ ‬crosses over‭. ‬
With the tailBeaconX‭, ‬we can now see that these products were just a run-up in the company’s product-development plans‭. ‬Where the previous UAT devices would be fine for domestic U.S‭. ‬compliance below 18,000‭ ‬feet‭, ‬they wouldn’t work in Canada or into the flight levels‭; ‬for that‭, ‬you need a 1090‭ ‬MHz Mode S transponder‭. ‬
Believe it or not‭, ‬that’s exactly what the tailBeaconX is‮—‬a Mode S transponder‭, ‬WAAS GPS for position information and an LED taillight all in one crazy‭-‬compact‭ ‬unit‭. ‬Moreover‭, ‬uAvionix is working on Aireon compatibility‮—‬the GPS-based‭ ‬ADS-B equivalent Canada is considering‭. (‬If you’ve been paying attention‭, ‬you know that Transport Canada has been pressing for ADS-B compliance through Aireon‭, ‬which itself requires so-called antenna diversity‭, ‬or one antenna on the‭ ‬top‭, ‬one on the bottom‭. ‬That program‭ ‬was originally supposed to launch in‭ ‬2021‭ ‬but is currently on hold‭.)‬ Aireon testing has been completed but uAvionix has not yet received approval.
Weighing just 3.5‭ ‬ounces‭, ‬the tailBeaconX is a mere 4.4‭ ‬inches tall‭ (‬at the‭ ‬“wings”‭ ‬of the two antennas‭) ‬and 4.4‭ ‬inches deep as measured from the trailing edge of the antennas to the connector‭. ‬The depth inside‭ ‬the taillight well is only 2.3‭ ‬inches‭. ‬The antenna configuration is inherently‭ ‬“diverse‭,‬”‭ ‬with top and bottom elements that will be needed for Aireon compatibility‭. ‬Power consumption‭? ‬A flashlight-like half an amp‭.‬
uAtailBeaconX EXP 3a
The AV-20 display/control unit is quite compact and easy to install. Pitot and static lines plus power and data through the DB-9 connector.
Matter of Control
It’s fair to wonder that if the entire transponder is in the taillight‭, ‬how do you‭ ‬control it‭? ‬There are a few ways‭. ‬For‭ ‬one thing‭, ‬the tailBeaconX can be controlled through a common RS-232‭ ‬data‭ ‬connection‭. ‬And that means it must be connected by four wires‮—‬power‭, ‬ground and both input and output‭ ‬data‭. ‬Fortunately‭, ‬uAvionix has made the tailBeaconX compatible with existing data formats‭, ‬so it’ll respond the‭ ‬same way other remote transponders‭ ‬do‭, ‬making it an easy add-on for panels‭ ‬already equipped with ‬Grand Rapids‭, ‬MGL or other EFISes capable‭ ‬of managing a Trig STX-165‭ ‬or Apollo/Garmin SL 70‭. ‬If you have one of these EFISes and have been keeping that old Narco transponder on life support‭, ‬this may be the ideal replacement for you‭.‬
For a lot of owners‭, ‬the tailBeaconX‭ ‬will predict installation of an AV-20‭ ‬or‭ ‬AV-30‭ ‬display head‭. ‬Formerly known by the Aerovonics brand‭, ‬the AV-20‭ ‬and AV-30‭ (‬see our preview in the October‭ ‬2019‭ ‬issue‭) ‬are lightweight‭, ‬affordable‭ ‬backup instruments‭. ‬The AV-20‭ ‬fits‭ ‬into a 2 1/4‭-‬inch hole while the AV-30‭ ‬has many more features and fits into a‭ ‬3 1/8‭-‬inch cutout‭. ‬For the tailBeaconX‭, ‬the AV-20‭ ‬or AV-30‭ ‬provides control‮—‬setting‭ ‬squawk codes‭, ‬sending an ident signal and managing modes‮—‬but also provides baro information‭ to the transponder.‬
uAvionix tailBeaconX installed
The tailBeaconX mounted in the expected location, where the taillight used to be. The unit is amazingly light and compact.
Install Notes
Obviously‭, ‬the tailBeaconX is intended to replace a conventional taillight‭, ‬like‭ ‬you’d find on thousands of Cessnas‭ ‬and Pipers‭, ‬as well as a bunch of RVs‭ ‬in the wild‭. ‬As with the tailBeacon‭, ‬it’s intended to be powered by the nav-light circuit‭. ‬And that was the brilliance‭, ‬so to speak‭, ‬of the skyBeacon and tailBeacon products‭: ‬They were close to‭ ‬straight swap-outs for the lights they‭ ‬replaced‭, ‬made even simpler because‭ ‬they didn’t need anything from the avionics inside the airplane‭. ‬
For a retrofit‭, ‬then‭, ‬the tailBeaconX‭ ‬will be a more complicated affair‭. ‬In addition to installing and setting up‭ ‬the AV-20‭ ‬or AV-30‭ ‬heads‭, ‬you’ll need to run a shielded pair of wires to the‭ ‬existing taillight‭. ‬For their part‭, ‬the‭ ‬AV-20‭ ‬or AV-30‭ ‬can be hooked up fairly‭ ‬minimally‭, ‬with connections only to‭ ‬power‭, ‬ground‭, ‬data and pitot/static‭. ‬A nice touch is that both units come with‭ ‬“industry standard”‭ ‬1/4‭-‬inch quick-release connectors for pitot and static lines‭. ‬The AV-30‭ ‬will accept other connections for GPS data right now and is‭ ‬expected to grow to include autopilot control in the future‭. ‬If you have a compatible EFIS‭, ‬then the install is a matter of running the data wires to the tailBeaconX itself‭.‬
AV-20 display transponder modes
The AV-20 display in attitude mode (left) and on the transponder page (right). All transponder modes are managed through this device.
I tested the Experimental-only version of the tailBeaconX in my GlaStar‭. ‬One complication‭: ‬It didn’t have a taillight‭. ‬In fact‭, ‬I’m not certain that even if it did‭, ‬that the tailBeaconX would‭ ‬have been happy there‭. ‬That’s because‭ ‬the GlaStar has a fairly stubby lower tail cone fairing that’s quite a bit over-hung‭ ‬by the aluminum elevator‭. ‬uAvionix‭ ‬says the unit wants a clear view of the sky for a good GPS position solution‭. ‬Um‭, ‬that won’t work‭. ‬Even if you don’t have a GlaStar‭, ‬it’s worth considering‭ ‬where your existing taillight lives in‭ ‬relation to metal parts that could block the GPS signal‭. ‬
uAtailBeaconX EXP 6
The tailBeaconX inside the GlaStar tail cone—shining a light to nowhere, er, Bulkhead B.
For my application‭, ‬I mounted the‭ ‬tailBeaconX inside the GlaStar’s fiberglass tail cone‭. ‬Any concerns that the location would cause performance problems were disproved after my test flights‭. ‬The instrument itself shows NIC and‭ ‬NACp scores right on the face‭. ‬NIC is Navigation Integrity Category‭, ‬and ranges from 0‭ ‬to 11‭. ‬NACp is Navigation Accuracy Category for Position‭, ‬and also ranges from 0‭ ‬to 11‭. ‬In order to be considered functional‭, ‬NIC needs to be 7‭ ‬or greater and‭ ‬NACp 8‭ ‬or more‭. ‬In testing‭, ‬the tailBeaconX not only‭ ‬averaged above 9‭ ‬in flight‭ (‬and hit 8‭ ‬sitting in the hangar‭) ‬but the FAA PAPR reports showed no flags‭. ‬Likewise‭, ‬ATC had no issues with the transponder even‭ ‬at lower altitudes‭. ‬The tailBeaconX‭ ‬might be small‭, ‬but it had no problems getting the job done‭.‬
The User Experience
Obviously‭, ‬you’re going to interface with this transponder in an unconventional‭ ‬way‭. ‬For my flight testing‭, ‬uAvionix‭ ‬provided an AV-20‭ ‬head unit‭. ‬By itself‭, ‬it includes multiple clocks‭, ‬a backup attitude indicator‭, ‬a calculated angle‭-‬of-attack indicator and the new transponder interface‭. ‬The AV-20‭ ‬powers up on the transponder page‭, ‬which‭ ‬shows the squawk code prominently as well as NIC and NACp scores‭, ‬mode‭ ‬annunciation and other menu items‭. ‬It also powers up in the ALT mode‭, ‬so there’s really not much to do for a simple VFR flight‭.‬
To change the squawk code‭, ‬you first have to press both lower buttons at the same time‭. (‬Touching one or the other scrolls through the available screens‭.) ‬This step highlights the first squawk digit‭, ‬which you can change through‭ ‬the left-side buttons‮—‬it’s up to increment‭, ‬down to decrement‭, ‬one digit at‭ ‬a time‭. ‬Got it‭? ‬Then hit the right-side‭ ‬button to move to the next digit‭. ‬Press both lower buttons to accept‭. ‬
To change modes‭, ‬continue scrolling with the right button until the mode‭ (‬ALT‭, ‬ON‭, ‬STBY‭) ‬is highlighted‭, ‬then‭ ‬change it with the lower-left button‭. ‬When not in the digit‭- ‬or mode-setting process‭, ‬the upper left button tells the‭ ‬transponder to ident or‭, ‬with a long‭ ‬push‭, ‬to reset the squawk to 1200‭. ‬
This control scheme is logical but‭ ‬fussy‮—‬and not nearly as easy as using a traditional transponder‭. ‬Why‭? ‬It’s a small head unit‭, ‬none of the buttons is lighted and finding‭ (‬then pressing‭) ‬both buttons in the heat of turbulence simply isn’t as effortless as twirling knobs or jabbing a series of numbered buttons in sequence‭. ‬I appreciate the limitations of the small display and limited input choices‭, ‬but it’s still not an ideal interface‭. ‬
The AV-30‭ ‬head unit‭, ‬which was not available in time for this test‭, ‬has a lot more functionality than the AV-20‭ ‬and portends an‭ ‬easier time of it‭; ‬at least it has a rotary controller with a push-to‭-‬accept function‭. ‬I hope to update this story once an AV-30‭ ‬becomes available‭ ‬with the new transponder software‭.‬
The Bottom Line
Pricing for the Experimental-class tailBeaconX is‭ $‬2499‭. ‬uAvionix is currently offering bundle pricing, which makes the total $‬3194‭ ‬with the AV-20 control head‭ ‬or‭ $‬3794‭ ‬with the AV-30‭—that’s a savings of $200 to $300, depending upon the head unit chosen. ‬If you already have an EFIS that will talk to it‭, ‬this makes the‭ ‬uAvionix device a good alternative to‭ ‬remotely mounted Mode S transponders‭. ‬For example‭, ‬Dynon’s Mode S remote‭ ‬transponder runs‭ $‬2200‭ ‬but you’ll need some dedicated wiring for it as well as an antenna‭, ‬which is part of the tailBeaconX assembly‭. ‬It may also require a different‭ ‬GPS position source than you already‭ ‬have to be legal‭; ‬the tailBeaconX already‭ ‬has you covered with its internal GPS‭. ‬
The tailBeaconX is also‭ ‬less costly‭ ‬than Garmin’s GTX 345‭ ‬Mode S‭ ‬transponders that both have built-in GPSs‭, ‬though you also get ADS-B In features that neither the Dynon remote transponder nor the tailBeaconX offer‭. ‬And‭, ‬of course‭, ‬the panel-mount GTX 345‭ ‬is a stand-alone unit that requires no EFIS for control‭. ‬But for many new installations and retrofits especially‭, ‬the tailBeaconX is a terrific choice‭. ‬
For more information, contact uAvionix at 844-827-2372, or visit www.uavionix.com.
2 COMMENTS
  1. I am currently installing 2 AV30’s in my RV6 and removing my vacuum system. I am in Canada and was planning to get the tail beacon X in the not to distant future. I am wondering if I remove my KT-76A , is there a panel mount gps with the proper dimensions that would fit the hole left behind by removal of my existing transponder?
  2. Hi, Doug. Unfortunately, the KT 76 is 1.6 inches tall and the new, small-format GPSes are 2 inches. I had the same experience, removing a Narco AT-150 and installing a GNX 375. It took a little metalwork.
