Turnbuckles are usually used in control systems to apply the proper amount of tension to the cables. It is extremely important to ensure that they are properly secured from turning. The two primary ways are via safety wire or special clips. AC-43-13B explains the proper ways to secure them. This is not one of them!
Error Chain
Forty-amp Catch-22. Accidentally bumping the alternator switch uncovered a circuit-breaker problem.
Progress Report: Bits and Pieces of HOG
OK, so we’ve got that 100-watt solar panel firmly bolted to the hangar roof....
The Most Dangerous Thing in the Cockpit
Forget about all those sharp corners, the quantity of fuel aboard and the fire extinguisher you threw in the baggage compartment without tying it down. It is always important to at least consider the fact that the most dangerous thing to have in the cockpit when things go wrong is the owner of the airplane.
If you thing that turnbuckle is bad workmanship, I’ve seen a cable fork end sleeve that is supposed to be swaged where the “builder” just center punched it several times and claimed it was “good enough”,he got really mad when I rejected it.
Wow!
