The propeller of an airplane generates thrust that drives it through the air. In addition to propelling the airplane, the thrust of the propeller affects both stability and trim. The relationship between the thrust line and the center of gravity can produce throttle-dependent effects on the trim of the airplane and also affects its stability. … Continue reading Thrust Line Effects
