The $250 Smoke System
Why buy a commercial system when its easy to roll your own?
9
We’ve all craned our neck upward to watch airshow performers draw elegant smoke trails across the sky and secretly said, “That looks like fun!” Maybe it’s time to draw some of your own smoke trails with the $250 smoke system.
I looked at commercial smoke systems, and they seemed beyond what I could justify. After looking through some of my priceless “junk” collection, I realized one could build a perfectly adequate smoke system within a reasonable budget. For those of you who don’t have a lifetime collection of “useful” treasures, a complete materials list is provided with suppliers and item costs.
A little research told me that one needed between 0.4 gpm (gallon per minute) and 1.0 gpm of smoke fluid pumping capacity. The system detailed here pumps about 0.4 to 0.5 gpm, producing decent smoke trails for my Onex.
The smoke oil tank is a one-gallon plastic gasoline container with a few modifications. A larger smoke oil tank may be used if your aircraft has the CG tolerance and space for it. A fluid pickup flop tube was added, as well as a one-way check valve that allows air to enter to replace the fluid being pumped out while preventing spillage in other than positive-G maneuvers. To simplify and modularize the unit, I used E6000 Industrial Adhesive to glue the smoke fluid pump, solenoid valve, and check valve directly onto the container. The purpose of the normally closed solenoid valve is to prevent smoke fluid from siphoning out through the nozzles. I discovered this need when a puddle began to appear under my exhaust stacks.
smoke system 03
Inside end of the flop tube. The tube is glued into a -inch hole through the top of the fuel can. The inside end is weighted with four -inch stainless nuts.
The battery is a standard 1000 mAh 4s lithium battery from the radio-control world. The battery powers both the pump and the solenoid valve.
At the suggestion of smarter people, the lithium battery was wrapped in fiberglass cloth and relocated to its own metal box away from the smoke tank. The hazard is very low considering the short duty cycle and relatively low power draw, and the battery is taken out for charging. But just to be safe, it’s now in a metal box.
smoke system 04
The 1000 mAh 4s lithium battery comes from the radio-control world. It powers both the pump and the solenoid valve.
smoke system 16
The battery was wrapped in fiberglass cloth, then housed in a tin box away from the smoke tank.
Using automotive connectors, the system is wired with a push-to-talk momentary switch that controls both the solenoid and the pump. The switch is mounted in a small plastic block with Velcro straps that wrap around the control-stick grip. The basic wiring diagram for the system is shown below.
smoke system 19
Basic wiring diagram for the smoke system.
High-temperature plastic tubing is used throughout the system to get the smoke fluid from the container to the injection nozzles. A quick disconnect fitting after the solenoid valve allows the tank assembly to be removed from the aircraft for battery charging and refilling with smoke oil.
I also installed a cockpit shutoff valve to keep the tubing contents from draining when the tank is removed. (After I added the solenoid valve and the quick disconnect with a built-in shutoff, the cockpit valve is probably redundant. I’ll leave that up to you.)
smoke system 02
A push-to-talk switch controls the solenoid and the pump.
smoke system 08
The switch is mounted in a small plastic block and attaches to the control stick grip with Velcro straps.
The injection nozzles were purchased from McMaster-Carr and sized to flow a total of 0.5 gpm. You can install one larger nozzle in one stack, or if you have two stacks, one nozzle in each, as I did on my Jabiru 3300. The nozzles may be installed in one of at least two ways: They can be installed directly through the exhaust stack with band clamps and a stainless sleeve, or by inserting a tube up the stack through the outlet opening. The latter method causes a slight exhaust flow restriction but does allow installation without the need for drilling any holes in the exhaust system. In either case, the nozzle(s) should be at least 12 inches from the end of the exhaust stack(s).
smoke system 05
Nozzle flow with pump running.
Other than the through-the-pipe nozzle installation, the goal of this project was to not require any permanent modifications to the aircraft. One does need to route the smoke fluid tube through the firewall, but I suspect most will be able to find an existing firewall penetration that will accommodate it.
smoke system 09
This early single exhaust pipe installation had the nozzle too close to the exhaust pipe end.
Once through the firewall, the smoke fluid tube tees into two tubes, one for each exhaust pipe, or goes directly to a single exhaust pipe.
The fittings are held on with worm-drive clamps and a .060 stainless cover sheet. A generous layer of muffler cement is applied under the stainless sleeve to seal against exhaust leakage.
smoke system 13
Exhaust installation nozzle/tubing breakdown.
If you’ve always wanted to put on your own airshow, but didn’t want to invest in a commercial system, you now have an inexpensive way to take up smoking.
smoke system 18
Up-the-pipe nozzle/tubing schematic.
smoke system 17
Through-the-pipe nozzle sleeve schematic.
smoke system 12
Exhaust pipes with clamps and sleeves in place.
smoke system 01
Dual exhaust pipe installation tee.
smoke system 11
Commercial smoke fluids.
smoke system 06
Smoke system components are housed in a plastic toolbox. Foam padding surrounds the battery box and helps hold the tank in place.
smoke system 07
The box is closed and latched to secure the smoke system in flight.
Smoke System Components
Component Supplier Part # Cost Version
12 VDC pump Electronic Goldmine #G21177 $5.95 All
Pump adapter fittings Electronic Goldmine #G22237 $4.95 All
1-gallon (or more) plastic fuel container Hardware or auto parts store $15.00 All
Push-to-talk switch Electronic Goldmine #G1801B $4.99 (10-pack) All
4s 1000 mAh lithium battery Hobby shop $15.00 All
1/8-inch poly check valve McMaster-Carr # 47245K11 $5.84 All
-inch RC model fuel tube (1 foot) Hobby shop $2.00 All
Goop or E6000 adhesive Hardware store $6.00 All
-inch tube-to-tube connectors (2) McMaster-Carr # 52215K537 $13.18 All
Quick disconnect plug with shutoff McMaster-Carr # 51545K76 $15.11 All
Quick disconnect socket with shutoff McMaster-Carr # 51545K23 $13.31 All
Push-to-connect fittings, -inch NPTF threads x -inch tube (2) McMaster-Carr # 1901K29 $12.44 All
-inch stainless coupling (1-2) McMaster-Carr # 4464K212 $2.57 – $5.14 Through exhaust
16-gauge stainless sheet (2×6 inches) McMaster-Carr # 8983K115 $4.75 Through exhaust
Permatex 80335 sealer (3 oz.) Hardware or auto parts store $5.00 Through exhaust
Stainless worm drive coupling (2-4) McMaster-Carr # 5388K28 $8.34 Through exhaust
Push-to connect fitting, -inch NPTF x -inch tube McMaster-Carr # 1901K22 $10.00 Through exhaust
Steel compression fitting, -inch NPTF x -inch tube (2) McMaster-Carr # 52215K425 $12.48 Through exhaust
Push-to-connect fitting, -inch NPTF tee McMaster-Carr # 1901K14 $6.60 All
-inch OD stainless tube (1 foot) McMaster-Carr # 8989K91 $1.91 Through exhaust
1/8-inch OD stainless tube (3 feet) McMaster-Carr # 8989K121 $7.73 Exhaust insert
Misting nozzles, -inch NPTF (2) McMaster-Carr # 32885K143 $22.68 Through exhaust
Misting nozzle, 1/8-inch NPTF (2) McMaster-Carr # 32885K131 $20.22 Exhaust insert
1/8-inch NPTF x 1/8-inch tube compression fitting (2) McMaster-Carr # 52215K611 $29.30 Exhaust insert
1/8-inch NPTF x -inch tube compression fitting (2) McMaster-Carr # 51875K61 $6.14 Exhaust insert
Shutoff valve (optional) McMaster-Carr # 4796k55 $16.11 All
-inch high-temp tubing (10 feet) McMaster-Carr # 52355K57 $25.00 All
Electrical connector (Hopkins 2-pole flat extension) eBay # 47965 $2.16 All
Electrical wire (10 feet) McMaster-Carr # 8233T11 $6.46 All
Solenoid valve (HFS, 12 VDC, fuels, normally closed, -inch NPTF) eBay $9.00 All
Metal box Walmart $2.00 All
Fiberglass cloth eBay $5.00 All
Total (through the exhaust) $232.00
Total (exhaust insert tubes) $270.00
9 COMMENTS
  1. While I love the idea of a DIY smoke oil kit. The nozzles that you recommend using are rated for well below the exhaust temperatures typically found in most piston engines. I would be reluctant to use any of those as the highest temp rating is 400 degrees
    • The nozzles I used are stainless steel that has a melting point well above the EGT. One could even use brass nozzles, but they would suffer from corrosion in long term exposure at EGTs. I bought the nozzles from McMaster-Carr and they do rate the stainless versions at 800 F. I’m not sure why as the nozzles are not subjected to much stress and other sources limit 304 and 315 stainless to 1500 F in loss stress applications. Think about it this way, my exhaust headers are stainless and it seems to tolerate EGTs even when wrapped.
      • This is so cool and I definitely want to do this!! Thanks for the information,I really appreciate your efforts!! What size is the nozzle itself? I am just trying to figure out what nozzle size sothat I can get 0.5 gallon ls per minute.
        It only says : 1/8 inch nozzle but you do get different flow rates.
        Many thanks
        Tristan
        • You have to match the nozzle with the pump output pressure. That’s what determines the flow rate for a family of nozzles. I believe I specified the nozzle to use in the article provided you get it from McMaster-Carr. If you’re concerned do a flow test before installing the system in the aircraft. This is similar to the fuel flow test done to certify a homebuilt.
          If you have a valve in the system you can always throttle the pump output to get the flow you want.
  2. I’m not sure why they limit their nozzles to 400 F, especially the stainless ones. It’s the same material EGT casings are made from. In any case I used stainless nozzles in my system and never had any problem with them.
  3. Thankful to Murgatroyd , another Kitplanes author willing to use store-boughten stuff to do a simple problem without spending the family treasure. More power to you, sir.
  4. Do you know of any Vans RV’s that have had success with this system? I have a 190 HP Lycoming and I would use the 2 exhaust system.
  5. I’m looking for a smoke pump the one that you referenced in your article is no longer available through gold miners
    Is there another pump that you would recommend?
