Tempest AA470 Oil Filter Cutter
If you’re doing your own routine maintenance—and if you’re not, why not?—you’re going to need a means to open your canister oil filter after every oil change. There are choices on the market, and each design seems to follow a slightly different philosophy, even if the desired result is much the same: cut the base … Continue reading Tempest AA470 Oil Filter Cutter
