Tech Tip: Tailwheel Tune-Up
Keeping your plane on the straight and narrow.
There you are on the taxiway, doing the taildragger weave, canopy rolled back, elbow on the sill, new headset forming a 50-mission crush in your favorite baseball cap. With each swing of the nose you check your path carefully for small animals, loose children, and the old guys from the FBO porch who don’t run very fast. You’re being safe, smooth, and yes, very cool … until the little wheel in the back suddenly pops into full swivel and you run over a taxiway light. Oh the shame!
OK Ace, maybe your tailwheel maintenance is overdue. After all, the poor thing lives in a dirt storm. If it’s giving you a bum steer, follow these simple instructions.
The unit shown here is from Aviation Products, and is typical of the Homebuilder’s Special from Aircraft Spruce, a Van’s RV fork, and the popular Bell, Screaming Eagle, and JD Air Products. If it looks generally similar, chances are it works the same.
Maule units are different, but operate on the same principle. For Bushwheel, Lang, Scott, and Matco, you may wish to obtain a manufacturer’s drawing.
Start by propping up the tail with something sturdy. Remove at least one tailwheel chain, and then remove the big nut and washers on top. Lift off the control arm and wipe it clean. Let it hang to the side for now.
Rotate the fork 90 degrees or more and the pin will be pushed back into the shaft.
The fork will now drop out. As it does, catch the spring-loaded pin with a fingertip. If the pin doesn’t pop out of the shaft, pull it out with pliers. Drop it and the spring in some solvent to soak.
Carefully clean the square bore where the pin fits in the shaft. Your best bet is a spray can of brake cleaner. You want to flush it thoroughly.
Now look carefully for burrs or damage. File or stone as needed. Flush it again until perfectly clean.
Inspect the square pin. Burrs, scars and gouges are common.
Lay a new sheet of 400 or higher grit on a hard, smooth surface. Lap the pin surfaces until the bumps and burrs are gone. Clean it carefully.
Inspect the slot adjacent to the main bore. Again, smooth and clean are the operative words.
Last, clean the control arm and inspect carefully right at the ends of the half-moon cutout. If burred, use a file or stone, but do not round off the sharp corner. If the corner is worn to a rounded shape, your best bet is a new arm.
Let’s reassemble. Clean and grease the main bore. Grease the pin and its recess. Slide the pin and spring into the recess, push in the pin until flush with the shaft surface, and slide the shaft up into the main bore. If the fork points rearward, the pin will snap into the slot when the shaft is fully inserted. The fork assembly will not fall out.
Add the arm, washer(s), and the big nut. Connect the steering chain. Push a grease gun on the fitting and pump until grease squeezes out around the top and bottom of the shaft.
Now might be a good time to check the wheel bearings for smooth operation. Most are sealed, but yours may need to be cleaned and repacked. You’re done! Go fly—just watch out for the old guys crossing the taxiway.
DanHorton 100px 2 clearpixel 230
Dan Horton says he is “just a homebuilder”. He has been a pilot more than 30 years and currently flies a custom RV-8.
Previous articleJust Aircraft’s SuperSTOL
Next articleEAA Founder Paul Poberezny Dies at Age 91
Dan Horton
Dan Horton has been crazy about airplanes since dope was a good thing. When not in the shop or researching some subject of interest, Dan can be found in his Van’s RV-8. He has been flying more than 40 years, and has not yet caused an international incident. That we are aware of, anyway.
