Shop-Made “Factory Heads”
Yes, it’s an oxymoron—a factory head is made in a factory, and shop heads are made in the shop—but the truth is, sometimes you can “fake” a factory head in the shop, mostly for aesthetic reasons. All it takes is a flush rivet (an “oops” rivet will do), a round-head squeezer die, a flat die, and a rivet squeezer.F1 Rocket Floor Panel img 3202
This is a floor panel for our F1 Rocket project. The hinge is for the bottom of the pilot’ seat back. The rivets you see all go into a stiffener that fits between the floor ribs. The two holes on either side (on the extension of the hinge material) will have screws that go into nut plates on the floor substructure. But when the floor panel is removed, those hinge extensions will be flopping around – I wanted them tacked down. But since they have to lay flush on the substructure, I needed a flush rivet head on the bottom.
F1 Rocket Floor Panel img 3203
First, I drilled a #40 hole close to the outboard screw hole location. This will be for our special rivet.
F1 Rocket Floor Panel IMG 3205
Next, a quick turn of a countersink from the bottom gave me a place to put a flush “oops rivet” – flush head “down”.
F1 Rocket Floor Panel img 3206
Here is the shank of the flush rivet stick up. Sure, I could just squeeze it and have a cylindrical factory head there, but it wouldn’t match the line of round-head rivets on the rest of the hinge material.
F1 Rocket Floor Panel img 3207
With an AD-3 round-head die in the top, and a fat die in the bottom, I squeeze the rivet, forming a “factory-similar” round-head rivet on the top of the workpiece—solely to match the rest of the rivets you can see from the top.
F1 Rocket Floor Panel img 3209
The final result doesn’t exactly match, but it I clearly from the same family of round-head rivets, and hides the little keeper rivet a bit better.
This could also have been a place to do a “double flush” rivet, where you countersink both sides and squeeze the tail flat into a countersink….but the material here was too thin to really make that work. And remember, in this case, it’s not engineering (there is no load on this)… it’s just art!
Previous articleDeltaHawk Announces Uprated Engines
Next articleFlying Tired
2 COMMENTS
  1. I like that your tip has the “look and feel” of the real world — as do your videos. It takes a few months or even years to come to the realization that most of the YT videos and builder website pics rarely display the less than “perfect” project pieces logic would indicate certainly exist.
