Quick-Drain O-Ring Change
Shortly before AirVenture I walked into my hangar, only to find a blue stain under the right wing tank. I keep a spare quick-drain sump plug on hand for just such occasions. After seven years of flying, that occasion finally raised its head.
I placed a clean bucket under the offending leak. I then removed the faulty drain and inserted the spare without losing too much fuel.
The question I struggled with was how to hold the quick-drain plug open while I changed the mini O-ring. A quick tour of my shop/hangar had me grabbing my trusty Cleco pliers. They turned out to be the correct size to hold the drain plug open, while I changed the O-ring. If you need two hands to install the O-ring, you can use rubber bands or safety wire to hold the Cleco pliers compressed.
Previous articleWhirlwind Visit
Next articleFirst Flights
Bill Repucci
Bill Repucci was handed his Private Pilot’s certificate back in the days when the written test was taken with a Number 2 pencil. At the time, Bill was told that he now had a “License to Learn.” And learn he did, mostly that there was humor buried in the quirky ways of those of us who call ourselves aviators.
