This month we use the accumulated flight-test data to determine what exactly is causing the unacceptable flying qualities of the airplane so that the best way to fix the problem can be identified;
Ponying up for the engine-monitoring portion of Garmins G3X EFIS suite requires careful consideration, but the result is a truly integrated solution. By Marc Cook.
