Plastic Tubing No-No
Unairworty.
plastic tubing no noThe symptom was a static system that leaked like a sieve when tested. Further investigation discovered this AN fitting being used with plastic tubing.
AN fittings are meant for hard aluminum/copper/steel lines where a flare of the tubing is required to make a seal.
Previous articleTwo Years On
Next articleDispassionate Pursuits
