Home Search
Rapid Prototyping and Experimental Design - search results
Lancair Evolution
Airplane development is never a straight, narrow path. From the initial design concept—hopefully imbued with savvy market research and a firm understanding of the category—through early development, prototyping, testing, building...
Lancair Evolution
Airplane development is never a straight, narrow path. From the initial design concept-hopefully imbued with savvy market research and a firm understanding of the category-through early development, prototyping, testing, building...
Wind Tunnel
...fixed-pitch propeller can efficiently deliver the rated power of the engine to the airplane at the airspeed and rpm at which it was designed to operate (its design point), but...
A Sign of the Zodiac (Part 4)
...introduced Sigtronics Sport 200S, which has been designed specifically for the non-certified Experimental and ultralight categories. Weighing only 6 ounces with all of the jacks and hardware, which are included,...
Engine Beat
...similar; the balls are of lower energy and velocity, but higher pressure.) Simple Designs The simplest design does away with length and collector tuning altogether, uses the shortest pipes possible,...
Builder Liability and You
...such a lawsuit-steps that can aid in your defense should even this unlikely event occur. Protection Starts in the Shop Builders of Experimental aircraft typically go to great lengths to...
A Futuristic Anachronism
...an eye toward the future. Hes a non-degreed engineer who helped design radar systems for the fi rst ICBMs. After retiring with that background in electrical engineering, he changed course...
Aero ‘lectrics, Strobes – Part 3
...capacitors are less expensive). Now no engineer in his right mind (oxymoron?) is ever satisfied with a design, and Im certainly not ready to sign this one off for production....
Light Stuff
...out beautifully built machines based on elegant designs, and Jihlavan is no exception.The KP-5 is imported by Kappa Aircraft in Pocono Pines, Pennsylvania, and is sold by the importer and...
...Built Category Aircraft (see www.casa.gov.au.). Also the U.S. is trailing Australia in certification of ultralights, and our LSA regs off er a lot more design standards and a widerrange of...
