Home Search
design process - search results
FITS Approval, Avemco Discount for the Savvy GPS Pilot Training Program
...to go from novice to confident GPS users in two days. To accelerate the learning process and maximize retention, Savvy GPS Pilot instructors use an integrated multimedia teaching technique called...
Sensenich Goes Composite, Introduces New Ground-Adjustable Prop
...internal-pressure-molded system. According to the company, this production process yields a durable, low-inertia propeller. The propeller is designed with a swept-blade planform for maximum efficiency. The EZ-pitch hub features a...
Avemco To Insure Pilots Transitioning to GlassCockpits
...transition training is often part of the purchase process), it will apply equally to homebuilders as well. According to Jim Lauerman, Avemcos chief underwriting officer, any pilot who wishes to...
Unison Unveils Autolite XL Fine Wire Spark Plugs
...the new plugs were designed with spark performance, long life and value in mind. The plug utilizes a pedestal mount for the welded side wire electrode, resulting in a projected...
HomebuiltHELP Offers Electrical Wiring Tutorial on DVD
...selection and wiring design with simple schematics that are applicable to a homebuilt electrical system. A discussion on proper wire type and sizing, fuses and connectors is supplemented with photos...
Oil Filter Cutter Added to Aicraft Spruce Catalog
...heavy-duty aircraft-spec aluminum, the cutters design ensures a straight, quick cut. It accepts filters from 3 1/8 to 4 inches in diameter and can be clamped to a workbench or...
...was made primarily for certified aircraft (in which factory-provided transition training is often part of the purchase process), it will apply equally to homebuilders as well. According to Jim Lauerman,...
Building a RotorWay 162F, Part 8
...a Seco 7 seal, which solved my problems. The Seco 7 is a soft, malleable crush washer designed for MS, AN and JIC standard 37° flared fitting assemblies. It’s designed...
Building a RotorWay 162F, Part 7
...work for a good while. And we were also trying not to kill ourselves in the process. About 3 hours into this mess, the ship was barely low enough to...
