NPT and Aircraft Fittings–Don’t Get That Size Wrong!
Plane and simple.
National Pipe Thread‭ ‬is a U.S‭. ‬standard for‭ ‬tapered‭ ‬threads‭, ‬which we find on many aircraft fittings‭. ‬Contrast this with‭ ‬straight‭ ‬threads‭, ‬which are used on the nuts and bolts that hold our aircraft together‭. ‬Tapered threads are used‭ ‬for‭ ‬sealing connections carrying gas and‭ ‬fluids‭. ‬In our kit aircraft we use all sorts of fittings with tapered threads such as‭ ‬those found on fuel lines‭, ‬brake lines‭ ‬and even avionic instrument air lines‭. ‬Our household water pipes use the same NPT tapered thread standard‭.‬
DSCN1222.ms
Components with NPT threads are common in aircraft fuel systems. Note that the blue AN fittings have NPT threads on one end and a flared tube connection on the other.
There are two important points to‭ ‬consider when selecting a tapered fitting‭. ‬First‭, ‬the way sizes are assigned to these fittings is not intuitive‭. ‬This may cause you grief the first time you need to‭ ‬order one from your favorite aircraft‭ ‬supplier‭. ‬The two most common sizes‭ ‬we use in our aircraft are‭ ‬1/8‭ ‬and‭ ‬1/4‭ ‬inch‭. ‬
ActualNPTfitting
The nominal size of an NPT thread fitting is not the same as its actual dimension.
However‭, ‬if you measure one of these fittings‭, ‬the size will not match any actual dimension of the part‭! ‬This is somewhat‭ ‬similar to expecting a 2×4‭ ‬piece of lumber to measure either 2‭ ‬or 4‭ ‬inches‭. ‬It is only a nominal size description‭ (‬in name‭ ‬only‭). ‬Without understanding this‭ ‬principle‭, ‬you will find yourself returning and reordering fittings because the diameter of the threaded portion may not fit your application‭.‬
setfittings
These are the popular NPT thread sizes used in homebuilt aircraft.
Using a chart‭, ‬you can determine the fitting’s nominal size by measuring the‭ ‬outer diameter of the threaded portion‭. ‬Fortunately‭, ‬there is an easy way to identify the two popular sizes‭. ‬If the outer diameter is less than‭ ‬1/2‭ ‬inch‭, ‬then you have a‭ ‬1/8‭-‬inch fitting‭; ‬if the diameter is a‭ ‬tad greater than‭ ‬1/2‭ ‬inch‭, ‬then you have a‭ ‬1/4‭-‬inch fitting‭. ‬The larger NPT‭ ‬fittings are less frequently found on‭ ‬our small homebuilts‭, ‬but measuring and using the chart will provide their proper size identification‭.‬
Nominal Size Actual Diameter
1/8 inch .405 inch
1/4 inch .540 inch
3/8 inch .675 inch
1/2 inch .840 inch
A fitting’s nominal size is determined by measuring the outer diameter of the threaded portion.
The second important point to remember when using NPT fittings is that a‭ ‬sealant‭ ‬must‭ ‬be used on the threads if you are interested in a leak-free connection‭. ‬This requirement is due to the microscopic channel in the spiral thread design that allows a path for leaks to occur‭. ‬A number of good choices for sealant are‭ ‬available depending on the application‭. ‬For example‭, ‬Loctite 567‭ ‬or similar‭ ‬products from Permatex work well for a fuel‭ ‬system‭. ‬A good sealant manufacturer‭ ‬will describe the compatible materials‭ ‬to be used with their product‭. ‬Avoid‭ ‬using plumber’s Teflon tape as small‭ ‬bits of this material are easily cut by the threads and can enter the system‭. ‬Also‭, ‬never confuse an NPT thread connection with‭ ‬a flare nut connection‭. ‬Sealant is‭ ‬never‭ ‬used in a flare connection but always used for an NPT connection‭. ‬
With time and experience you will soon be able to identify the nominal sizes of NPT fittings by just looking at them‭. ‬You will also be surprised how‭ ‬many of these fittings your finished‭ ‬aircraft uses‭.
Previous articleFixed-Pitch Props
Next articleOff the Grid (Chapter 2)
Jon Croke
As the founder of HomebuiltHELP.com, Jon Croke has produced instructional videos for Experimental aircraft builders for over 20 years. He has built (and helped others build) over a dozen kit aircraft of all makes and models. Jon is a private pilot and currently owns and flies a Zenith Cruzer.
