New Wingtip LED Light System
ledcombo 11Kuntzleman Electronics introduces the LED Combo, a new wingtip strobe anti-collision/navigation light system. This cluster of very bright LEDs uses a common controller that furnishes the heads with a junction point for synchronizing and selecting one of seven flash patterns. The system also allows for a separate power source to the navigation red, green and white LEDs.
The system includes two heads, mounting adapter plates for mounting on a radius, 50 feet of three-conductor wire, plugs, pins, one controller, miscellaneous wire connectors and mounting hardware. Also available at no additional cost (if mentioned at the time of purchase), are Combo adapters for Sonex, the BushCaddy and trikes. The introductory price is $399.
Established in 1983, Kuntzleman Electronics is a pioneer in aircraft lighting for Experimental, Light Sport and ultralight aircraft.
SPECIFICATIONS
Navigation colors: Aviation red/green forward and white aft.
Strobe: Synchronized with seven selectable flash patterns.
Weight: Two heads and controller: 12 ounces.
Power draw: Strobe and position lights are less than 2 amps at 12 to 14 volts.
For more information, visit www.Kestrobes.com or call 610/326-9068.
