Marking a Constant Gap
Save time and effort marking a uniform trim distance.
Many times, a builder needs to mark a constant gap, or distance, from an irregularly-shaped line. An example would be trimming a wing intersection fairing so that there is a constant gap between the fairing and fuselage for a seal. You can do this by measuring every inch, then connecting the dots—or much more quickly using a scrap of material with a hole drilled at the correct gap distance. Drill the hole the size of the tip of a Sharpie fine-tip marker, and the tool is complete!
shop tip 01
A short scrap of aluminum, bent to make a handle, is all you need to make this special tool. Dressing the edges makes it slide easier.
shop tip 02
The hole should be sized to perfectly fit the marking utensil to be used—in this case, a fine-tipped Sharpie.
shop tip 03
The tool in use—saving time and effort to mark a perfectly uniform trim distance.
