Light Stuff
Power up from Down Under.
light 3300
Partially installed, this 120-hp Jabiru 3300 shows off its CNC-machined crankcase and cylinder fins.
Australians Rodney Stiff and Phil Ainsworth didn’t start out to build engines. Their goal was to develop a sport airplane, and they founded Jabiru in 1988 to produce a light airplane in what is now the U.S. Light Sport Aircraft (LSA) category. Their first Jabiru airplane was based on the lightest four-stroke aircraft engine available, the Italian KFM. But one month after the Australian Civil Aviation Authority certified the original Jabiru, KFM announced termination of its aviation engine production.
Power Problems
Jabiru wasn’t the first aircraft company to be brought up short for lack of suitable power. In recent years, the Eclipse jet project faltered with the company claiming that the Williams turbines on which the concept was based, failed to perform to spec. Earlier, the Jim Bede BD-5 program suffered its first major setback when German manufacturer Hirth failed to produce the 40-horsepower two-stroke being developed for the airplane. Both Eclipse and Bede failed.
Lemons to Lemonade
Stiff and Ainsworth, however, chose another route: They designed from scratch and produced their own engine. A four-stroke, 1600cc engine came first, and it was certified in 1993. Fifty-four Jabiru aircraft with the 1600cc Jabiru engine were built from 1993 to 1996. At the 1994 EAA Oshkosh fly-in, the Jabiru 1600 engine was displayed, and positive feedback led the company to begin developing an 85-hp, 2200cc version.
Less than seven months later, the first Jabiru 2200 was shown at Floridas Sun n Fun fly-in, and six months after that the first 24 Jabiru 2200s were ready for shipment. Small-company enthusiasm, flexibility, computer design and CNC manufacturing combined to compress the usual development period from years to only months. Stiff acquired full ownership rights in July 2005, and Jabiru is one of the few companies in the world that produces both aircraft and its own powerplants.
The Engines
Presently, three Jabiru engines are available: the four-opposed-cylinder 2200, a six-cylinder 120-hp 3300 and the eight-cylinder 180-hp 5100, which has been on-again/off-again recently, and is now officially on again. The three engines share many features:
  • Crankcase, cylinder fins and many other parts machined in Australia from aluminum billets produced by an Australian company. Only the oil pan is cast.
  • Cylinders and crankshaft are machined from 4140 chrome-moly bar stock.
  • The centrally located single camshaft is from a cam specialty company.
  • Direct drive; no gearbox.
  • Dual fixed-timed magnetos; no battery required for ignition.
  • Automotive NGK spark plugs.
  • Provided with one altitude-compensating Bing carburetor (two on the 5100).
  • Removable prop flange for easy front seal replacement and prop extension.
  • Integral 20-amp alternator driven directly by the crankshaft.
  • 1-kilowatt starter made by Jabiru.
  • Internal, mechanically driven fuel pump.
  • Wet sump oiling system with a spin-on oil filter.
  • Supplied with RamAir ducts that simplify homebuilt installations by eliminating typical engine baffling. Ducts are available for tractor and pusher installations.
  • A vacuum pump drive accommodates suction-powered instruments.
  • Stainless-steel exhaust is included.
The 2200 and 3300 engines currently feature 8:1 compression, allowing the use of 91 octane auto fuel or 100LL avgas. The 5100 engine compression ratio is 8.5:1 and requires 100LL gasoline.
Applications
These engines are of course used in all of Jabirus ready-to-fly aircraft and Experimental-category kits. The airplane line includes five two-seat factory-built Jabirus (all qualify as U.S. LSAs) and four kits. One of the kits (the Jabiru 3300-powered J430) accommodates four seats.
light 2200
Like the other Jabiru engines, the 85-hp 2200 model is physically small and comes with molded air intakes that simplify installation.
The Indus line of factory-built LSAs features Jabiru power, and many Experimental-category homebuilts may use Jabiru engines, for which Jabiru has developed partial firewall-forward packages. The list of dozens of Jabiru-capable homebuilts currently includes the Evans VP1, many models of Avids and Kitfoxes, Europas, the Murphy Rebel and Renegade, RANS S-6 and S-7, Sonex, Pulsar, RVs 6 through 9, Zeniths CH 601, 701 and 620, TEAM AirBike, Dragonfly and others. In most cases, factory-built engine mounts are available, and in some cases, replacement cowls may be purchased. The wide variety of designs accommodated-from the single-seat ultralight TEAM AirBike to RVs-results from the range of horsepower (85 to 180) in the Jabiru engine lineup.
Support
The factory web site lists Jabiru connections in 62 countries, and it notes companies that offer engine maintenance including overhauls. Recommended TBO is 2000 hours with a top overhaul expected at 1000 hours of engine time.
The factory web site (www.jabiru.net.au) and the Jabiru USA Sport Aircraft site (www.usjabiru.com) can provide considerable support. The Jabiru USA site, for example, lists what to do before a new Jabiru is started. Of course, this information is also available in the owners manual, but potential customers may also benefit from these details during the decision-making process.
The Australian factory web site contains 19 service bulletins dating from early 2000. A recent nine-page letter addresses using gasoline containing ethanol in a Jabiru. Although avgas is preferred to ethanol-laced auto fuel in these engines, the letter notes that fuel up to E-10 (10% ethanol) should cause few problems if it is fresh. The extent of possible damage relates to the compression of the subject engine and even its combustion chamber shape. Knowing the engines serial number and overhaul history will help the owner make a decision on whether to use ethanol-blended fuel.
Opposite ends of the thermometer-cold-weather starts and high oil and head temperature in the air-are addressed on the U.S. site. Wisconsin winter engine starts are easy with 20 minutes of preheating from a $30, 1500-watt heater blowing warm air in the right place, the web site notes. It also advises that proper positioning of the oil cooler and air inlets of the right size and shape will preclude overheating. Air inlets that are too large can result in inefficient cooling and excess temperatures. Many other technical details are available on these two Jabiru sites.
The standard Jabiru engine warranty is 500 hours or two years, whichever comes first. Normally, the clock starts from the date of delivery, but if arranged, the warranty may begin with an independently verified first flight.
Firewall-Forward Kits
Jabiru USA Sport Aircraft has developed complete engine installation packages for some homebuilts. So far, firewall-forward kits are available for the Zenith CH 601, CH 701 (for both 2200 and 3300 Jabiru engines) and the RANS S-7S. A package is in the works for the RANS S-19.
Heres what comes with the Jabiru 2200 engine installation package for the CH 601: engine mount, a new cowl with molded air intakes and an oil door, oil cooler, Sensenich fixed-pitch propeller (a composite prop is optional), molded spinner, prop extension, battery box, carb heat, braided hoses and vernier throttle (dual throttles optional). The price is $3450. For the Jabiru 3300 engine in the 601, the installation package is $100 more. A very effective cabin-heat option adds another $319.
Engines on Demand
Pete Krotje, who heads Jabiru USA in Shelbyville, Tennessee, said the 2200 and 3300 engines were in stock when this was written, and the Jabiru 5100 could be delivered about 50 days after an order. Engine prices were $12,500, $16,500 and $25,000 respectively. My experience with Jabiru engines is limited, but their reputation for smoothness, reliability and efficiency appears to be well deserved.
DaveMartin 100px 4 clearpixel 936
Dave Martin served as editor of this magazine for 17 years and began aviation journalism evaluating ultralights in the early 80s. A former CFI (airplanes, gliders, instruments), hes flown more than 160 aircraft types plus 60 ultralights (including a single-seat, no-basket hot air balloon). Now living at a residential airpark in Oregon, he flies his Spacewalker II homebuilt as a Sport Pilot.
