Cut the Can, Man
Inspecting your filter after an oil change is a good idea, but what tool is best for opening the can? Bob Fritz tests the gamut of oil filter cutters so that you don't have to.
Variable Geometry Cooling System
The way to reduce or eliminate excess cooling drag in cruise is to use a variable-geometry cooling system that can change shape to control the amount of air flowing through the cowling.
Build Your Skills: Fabric
This month we look at installing the fabric on the wing and how to use rib-lacing, reinforcement tapes, pre-punched holes, and methods of mechanical attachment including pop rivets, PK screws and fabric clips; by Ron Alexander.
