The Home Machinist
Taking that first cut into the sheet metal of an aircraft panel can be daunting, and being as precise as youd like is even more so. Author Bob Fritz eases your anxiety about the process with some tips about how to use the right tool for the right job, so that the hole you get is the one you wanted.
Reverse Engineering a Glasair Tailwheel
One day last summer, seconds after rolling from the hold short line to depart...
Cracked Landing Gear Weldment
Landing gear sockets should be checked regularly for those who fly off of grass...
