When the Rooster Flies
Just because real roosters don't fly doesn't mean that a 100%-original aircraft designed and painted to resemble one wont.
This month DAR Mel Asberry tackles questions about modifying an aircraft and the flight testing required, what should be on a dataplate, and what you need to know about getting an airworthiness certificate after completing a partially built aircraft.
Where Do Airplane Parts Come From?
Building your own replacement kit parts, which is no different than scratch-building from plans, may save you money and time.
