Searching for the Right RV-6
If at first you don't succeed, keep looking-sooner or later you'll find it!
All About Avionics: Panel Labels
Avionics wiz Stein Bruch discusses the pros and cons of the most popular ways of labeling your panel including placards, decals, rub-on labels, silkscreens and laser etching.
Design Process: Wing Structure
Last month we started our discussion of wing design with a look at the...
Homebuilt Accidents: Passing the Engine Baton
How does the Rotax 912 compare to traditional engines used in small homebuilts?
Engine Mounts
Many factors go into designing and building good engine mounts, including consideration of the engines thrust line and gyroscopic precession effects. They deserve our respect.
