How To Bend Tubing Without a Tube Bender
Home shop machinist.
tube bending 01
If one were to think this 1940 textbook on aircraft maintenance by Brimm and Boggess would be useless in the year 2024, one would be wrong. In the process of studying the old-school techniques to understand how we got to now, I found many useful how-to tips.
If you need to bend tubing on a regular basis, especially 4130 steel, the go-to tool for small shops is the JD Squared Model 32 tube and pipe bender (see the August 2017 issue of KITPLANES). But what if you only have one or two bends to make? Surely there must be a way to get a simple bend in an aircraft tube without having to invest in a bender and an expensive die set. That was the situation with my neighbor, Paul Dye, this summer. He was looking to make simple 15° bends on two ⅞-inch x 0.065-inch 4130 tubes for control sticks for his F1 Rocket project. How hard could it be? Might an inexpensive Harbor Freight pipe bender work? The answer: no. The first try kinked the tube almost immediately. A second attempt was made after packing the tube with sand, the theory being that sand will prevent the tube from collapsing. While the sand helped, the tube still kinked. The conclusion: You can use a tube bender to bend pipe, but you can’t use a pipe bender to bend tube—at least not thin-wall aircraft tubing.
tube bending 10
Paul’s stick morphed from one bend with a 15° dogleg to an “S” with two 3-inch-radius 45° bends (left). The first attempt at bending with a Harbor Freight hydraulic pipe bender kinked the tube at the apex of the bend (middle). Packing with sand helped, but not enough to prevent buckling (right).
On to plan B, which was to try the heating and bending method that I read about in a 1940 textbook, Aircraft Maintenance by Daniel J. Brimm and H. Edward Boggess, on page 217:
“The instructions below apply particularly to steel, aluminum and aluminum alloy tubing. The bending of copper tubing for gas and oil lines is taken up in Aircraft Engine Maintenance.
“It is quite difficult to bend tubing around a radius of less than six times its diameter. Even with the radius this large, care is required to prevent buckling inside of the bend and flattening the outside. Unless the bend to be made is very gentle, a bending form, preferably of hardwood, should be made. If only one piece is to be bent, and if the radius of the bend is fairly large, it may not be necessary to groove the form. A more satisfactory job will result, however, if the form is grooved. The bottom of the groove should be smooth and fit the tubing accurately.
tube bending 03
The bending form was turned from a round blank of hardwood left over from the spinning project (see KITPLANES April 2024). The round was turned to just over 6 inches to make the 3-inch centerline bend radius (left). The face of the cylinder was measured and margins marked for the ⅞-inch tube width (middle and right).
tube bending 04
The groove was roughed out using a scraper tool (left) and checked frequently to avoid overshooting the target diameter (middle) and to confirm the correct profile (right).
tube bending 05
About 0.025 inch was turned off the OD of a 5-inch-long section of ⅞-inch 4130 tube. It was then wrapped with 100-grit sandpaper and used to sand the groove (left) until it was a perfect fit for a ⅞-inch tube (right).
“The next step is to drive a tight-fitting wooden plug into one end of the tube, which should be sufficiently long to extend far enough beyond the form to hold it satisfactorily. Then fill the tube with sifted sand, rapping it sharply with a block of wood as the sand is being poured in so that there will be no empty spaces left. When the sand has filled the tube and been well packed down, the open end should be plugged and the tube heated with a torch. If the material is steel, bring it to a bright red. If aluminum or duralumin is being bent, it should be heated until it will char paper. [In pre-1970 terminology, 2XXX series alloys were known as duralumin.] Aluminum does not change its color when heated and will melt without losing its silvery luster. When the tube has been heated to the proper degree, an assistant holds one end while the other end is bent around the form. The thinner the gauge of the tube, the harder it will be to bend without buckling.”
tube bending 06
The end caps were cut from ⅛-inch steel plate using a 1-inch hole saw (left). The slugs matched up perfectly to be tack welded in place (right).
tube bending 07
With one end plugged, the tube was filled with sand and packed as tight as possible (left). Experience with previous sand packing led to the idea of adding a ¼-20 screw plunger on the end cap to further compress the sand after the end cap was tacked on to seal the sand in the tube (right).
Further down the text mentioned that “In production, the form is usually made of cast iron, as the wood burns away after a time.” No kidding!
tube bending 02
The wood bending form was cut in half using a band saw and the two halves were laid out on a piece of 3/4–inch plywood and screwed in place.
By this time, the design for Paul’s stick had morphed from one bend with a 15° dogleg to an “S” with two 3-inch radius 45° bends. Although that is significantly tighter than the minimum radius suggested in the text (6 x ⅞ = 5¼ inch), it made for the optimal control stick. After a bit of figuring, it seemed doable using the wood lathe to make the bending form and Paul’s oxyacetylene rig to provide the heat. Plus, I knew that if this didn’t work out, plan C was to get my buddy Billy Griggs to rescue the project using his Model 32 bender with a 3-inch radius die.
tube bending thm
With the bending jig clamped firmly to the welding table and moved outside, the region of the first bend was torch heated to red hot, then a 3-foot length of pipe was used to lever the first bend around the form. A spritz of water from a spray bottle extinguished the flare-up.
tube bending 08
The region of the second bend was torch heated to red hot (left). Not the screw plunger on the end cap and the Kevlar kiln gloves (rated to 1000° F) used to hold the tube. Making the second bend (right). While it looked like the tube was hot enough to bend, it was not. The force required to get the tube to conform was significantly higher than the first bend. This resulted in a squished bend. Despite the scorch marks, the forms looked good enough to be used again.
tube bending 09
A comparison of the two bends (left) clearly shows the first bend was a success (middle) while the second bend (right) squished because of my failure to get it hot enough. Packing with sand helps, but only if you get the tube hot enough.
It was quite fun trying out this “retro” procedure and we proved it can work, provided you can get enough heat into the tube. If you’re interested, the book is available (as of this writing, July 2024) from Amazon and other sources. That’s it for now. It’s time to get back in the shop and make some chips.
3 COMMENTS
  1. Bending tubing is a art in itself. I learned the process myself. I have a professional hand bender to bend 1 inch, 1-1,8 inch and 1-1/4 inch 6061 t6 aluminum tubing. I still have it and it is in my storage. I used it to make ultralight aircraft. I also have the over the counter benders for 1/2 inch and 3/4 inch tubing. It can bend the steel tubing for aircraft fuselages. It is an art to bend tubing. keep my number handy if anyone inquires about needing some made. My tubing bender is based on a 4 inch radius. It is made of solid steel. But it is not hydraulic. Contact me at 979-885-9145 or kimazorzi@gmail.com thanks for the tubing bender article.
  2. In my personal experience, I find older books to be more useful and easier to learn from than newer books. They read better, explain things better and more simply and effectively. I always appreciate a good book recommendation, even older ones.
    As time goes on, knowledge changes and updates, and so always good to cross reference older books against newer sources of information, but in general the basics of a particular never really change.
  3. Another helpful “tool” is cerobend. It is a low melting point alloy that you pour into the center of the tube helping to prevent collapse. You melt it out when done.I will use it even when using a tube bender.
