The majority of airplanes use the conventional tail configuration with a single, centrally mounted vertical tail and rudder. Sometimes, however, the vertical tail is separated into two or more surfaces. One such configuration has vertical fins mounted to the tips of the horizontal tail. These fins can be the only vertical tails on the airplane … Continue reading H-tails and Triple Tails
