Gelato Aids Aircraft Construction
DSCN7769 e1742575102613
EAA Chapter 534 members Stan Carpenter, Mark Banus, and Wayne Broadfield, connoisseurs of Talenti gelato. A set of shelves to hold all those Talenti containers of aircraft fasteners was built by chapter members John Weber and Frank McCutcheon Sr.
Sometimes, necessity becomes the mother of invention—which leads to thinking outside the box.
Every once in a while, some of the most mundane and obvious things we have around the house suddenly become a necessity in a busy hangar where aircraft building is taking place.
This is just what happened in the Experimental Aircraft Association Chapter 534 hangar at Leesburg International Airport in Leesburg, Florida.
DSCN7786
The product to look for in your local grocery store looks like this and comes in a variety of flavors. Afterwards, you end up with a practical clear plastic one-pint storage container with a screw top.
For example, empty and washed Talenti gelato or sorbetto containers with screw tops make excellent containers for the nuts, bolts, washers and rivets needed for building an airplane.
In Chapter 534’s situation, these containers gradually started to accumulate at workstations within the chapter hangar.
The Hangar Monkeys—chapter members who show up to build and repair aircraft—no longer have to scour the hangar trying to find the right-size nut and bolt or some other exotic fastener.
Thanks to three husband-and-wife couples who enjoy a tasty frozen dessert called Talenti gelato, the Chapter 534 supply of aircraft fasteners is now organized and on display at various workstations in the hangar.
This ice cream treat becomes the source of the crystal-clear containers that can be purchased at most grocery stores.
Now, because of these pint-size plastic containers, much less time is wasted searching the hangar for the correct nut or bolt—and you’re helping the environment by keeping plastic out of the landfill.
DSCN7764
The Murphy Rebel workstation in the EAA Chapter 534 hangar in Florida.
Granted, someone has to take the time to do the sorting in the beginning, but once the system is set up and placed in convenient locations, everybody saves time.
During the sorting process, members learn what sizes of nuts and bolts are on hand and where they are. They also learn what other fasteners they might need to buy to round out the supply.
Blue masking tape is placed on the outside of each container or on the top of the screw-on lid, and the contents are noted with a black Sharpie. By picking up the container and looking through the clear plastic, it’s easy to verify that you’ve found what you need.
This very simple, time-saving solution facilitates aircraft building and repair in your hangar or shop—and besides, you get to enjoy a delicious dessert treat.
  1. Means someone has to sacrifice themselves and eat all that ice cream. Currently between projects, but decided I need that organization system.
