Flush Rivet Removal
There can be more than 10,000 rivets in an aluminum kit aircraft. Given that many opportunities for errors, you’ll surely need to replace a few. Don’t worry…removing AN426 flush rivets is easy if you follow these five simple steps.
shop tip 005
Fig. 1
First, use a sharp prick punch to mark the exact center of the rivet. (Fig. 1).
shop tip 006
Fig. 2
Use a low angle center punch to form a wide dimple for drill guidance (Fig. 2).
shop tip 007
Fig. 3
Use a new, sharp drill bit. Drill only to a depth equal to the thickness of the head. Never drill all the way through the work. (Fig. 3).
shop tip 008
Fig. 4
Break off the head using a rod or punch with a sharp squared tip (Fig. 4). The tool here is just a short section of scrap welding rod.
shop tip 009
Fig. 5
Now use a punch to push out the rivet shank (Fig. 5). Note the undamaged dimple.
shop tip 002
Fig. 6
If the workpiece is thin-gauge aluminum, the material around the hole may be deformed or bent when you strike the punch. To eliminate damage, drill 0.1875-inch and 0.250-inch holes in the end of a spare bucking bar (Fig. 6).
shop tip 003
Fig. 7
Simply place a suitable hole under the shop head of the rivet before you strike the punch (Fig. 7). Given good support the aluminum will not be deformed and the rivet shank will pop right out. Don’t have enough hands to hold a backup bar, a punch, and a hammer? It doesn’t take much force to pop the rivet shank out of thin material, so try using your spring-loaded prick punch instead. With a clean, undamaged hole you’re ready to set a new rivet. Have fun!
