Flight Testing: Static System Error, Theory and Practice
We look at troubleshooting this system as preparation for flight testing using the speed course method.
static panel
All the high-tech flight instruments wont help much if the basic pitot-static system contains inherent errors. Read the story to learn how to find them.
Most owners of amateur-built aircraft are interested in knowing how well their airplanes perform, and airspeed is an important parameter in all types of aircraft performance measurement. But aircraft pitot-static systems have many possible sources of error that may affect indicated airspeed and altitude. Thus, before using your indicated airspeeds to determine performance, it would be wise to determine what the error is in the airspeed indication system.
static manometer
Frank Karastis water manometer.
In the August issue of this magazine, we covered the use of GPS to determine TAS (Finding TAS from GPS Data). This time well discuss the causes of various pitot-static system errors and describe the speed course method to measure static system error. Well also look at details of the ground and flight tests required to support the speed course method. The next article in this series will show how to analyze the results of the speed course flight tests, and describe some ways to possibly reduce static system error if it should be too large.
Pitot System Errors
The pitot tube senses the total pressure of the airflow. Total pressure is the sum of the static pressure and the dynamic (or ram) pressure. One of the niceties of the laws of physics is that the total pressure remains the same as the airflow accelerates and decelerates around the aircraft. If the airflow accelerates, the dynamic pressure increases, but the static pressure decreases (Bernoulli’s Law), and the total pressure remains the same.
static port
The static port on an RV-8.
The pitot tube will give accurate readings as long as it is well clear of the prop wash, not in the boundary layer, not in the wake of some projection and aligned with the local flow within about 15 (maybe to 20 for pitot tubes made from tubing, according to NASA-Reference Paper-1046, Measurement of Aircraft Speed and Altitude). This condition may be violated at high angles of attack, which is one reason most airspeed systems read low at the stall.
The pitot system is subject to leaks and should be checked. If the airspeed and altitude are constant, there is no air flowing in a pitot system: The pressure at every point inside the pitot system equals the pressure at the pitot tube. Small leaks near the pitot port have little effect, as the small amount of air that is lost will be replenished by air coming in from the pitot tube with negligible pressure loss. Leaks further downstream are more significant, as they will cause a continuous flow of air in the pitot system. A pressure drop is required to force air to flow, so the pressure at the ASI will be less than the pressure at the pitot port if there’s a leak.
static connection
Pitot- and static-line connections to instruments, whether conventional or to external AHRS modules, need to be leak free to ensure accurate airspeed readings.
Generally, a leak-free pitot system will be error free, except near the stall, where there may be a large angle between the local flow and the pitot tube. Airspeed errors away from the stall are likely due to the static system or ASI error.
Static System Errors
The static system is much more prone to errors than the pitot system. The purpose of the static system is to measure free-stream ambient pressure. This is a bit of a trick, because the aircraft causes the airflow to accelerate and decelerate as it passes by. Bernoulli’s Law tells us that the static pressure will change as the speed of the air changes, so it is difficult to find a place where the local pressure is the same as the free-stream ambient pressure. The difference between the pressure at the static port and the free-stream ambient pressure is the static system position error.
The static system is also subject to leaks. The pressure in the cockpit usually differs from the ambient pressure, so leaks in the static system expose it to this incorrect pressure.
ASI Instrument Error
The airspeed indicator is subject to instrument error and should be calibrated. See Maintain thy airspeed, lest the ground rise up and smite thee by Jim Weir, February 2009 KITPLANES for details on how to use a homemade water manometer to calibrate an ASI. Note: The data tables in that article are in error. See How to calibrate your ASI, Jim Weir, July 1989, for correct tables of ASI reading versus water manometer height. Or, use the asi_cal.xls spreadsheet listed in Resources.
Speed Course Method Background
Large companies use various methods to measure static source error, but most require expensive equipment and/or dedicated ground support personnel. But the long-established speed course method has seen a renaissance due to development of inexpensive GPS units.
The speed course method relies on the following assumptions:
  • No pitot or static system leaks
  • No error in the pitot pressure
  • ASI instrument error is known
  • TAS and OAT are accurately known, allowing calibrated airspeed (CAS) to be calculated.
Thus, the difference between CAS and IAS, once we account for ASI error, must be due to errors in the static source. In days past, the TAS needed for this method was determined by timing two-way runs past ground reference points, using a stop watch. This required flying in the early morning to find smooth air at low altitude. The advent of GPS allows the speed course method to be flown in the smooth air we find at altitude. We will determine TAS as described in Finding TAS from GPS Data in the August 2009 issue of KITPLANES.
Ground Testing
These ground-test items must be completed to validate the assumptions:
  • Conduct a pitot system leak check. Apply pressure to cause the ASI to indicate 150 knots (or the highest ASI reading, if less than 150 knots) and hold pressure. After 1 minute, leakage must not exceed 10 knots (from FAA AC 43.13-1B Section 12-59). Release the pressure slowly to avoid damaging the ASI.
  • Conduct a static system leak check. Note the altimeter reading. Apply suction to the static pressure system so that the altimeter increases 1000 feet and hold the pressure. After 1 minute, the loss of indicated altitude must not exceed 100 feet (from FAA AC 43.13-1B section 12-58). Release the suction slowly.
  • Calibrate the ASI as described.
  • Check the OAT gauge calibration. The accuracy at 32 F (0 C) can be checked by placing the OAT probe in a water/ice bath.
Typical small altimeter instrument errors are not critical for this test method, but if there is any question about the serviceability of the altimeter, it should be checked by an instrument shop.
Flight Testing
The flight testing must be done in smooth air. The test technique assumes constant wind direction and speed, so avoid testing during weather conditions that may give wind shifts such as those that occur near cold or warm fronts.
Fly four legs at a constant heading, altitude and airspeed. The run directions should be about 90 a part. All runs must be at exactly the same airspeed, but the altitude may be varied 50 feet of the target if required to obtain exactly the target airspeed. For each run, record:
  • IAS
  • Pressure altitude (with altimeter set to 29.92 in Hg or 1013.25 mb)
  • GPS ground speed
  • GPS track
  • OAT
  • Fuel remaining
Allow time for the GPS speed and track indications to stabilize before recording data.
The more accurately you can fly the test points, the more accurate a result you will obtain. If possible, it is useful to have a second person in the aircraft to record the data accurately and watch for other traffic.
Test Card
The next article in this series will present actual flight-test data from a static system position error flight test on the authors RV-8. The data will be analyzed using a spreadsheet to determine the airspeed and altitude errors resulting from the static system position error. Meanwhile, your homework assignment is to do your own ground and flight testing, so that you have some data ready to analyze when the next issue arrives.
