Bearhawk Aircraft announced today the first flight of a Bearhawk Companion, side-by-side two-place aircraft. The Companion is a utility aircraft with backcountry flying characteristics. It derived from the tandem seating Bearhawk Patrol wings and the 4-Place Bearhawk Model 5 fuselage.
Design goal cruise speed of 145 mph (126 knots indicated) has been met, as well as payload target of 1,070 lb. The first flight of a Bearhawk Companion was performed by the aircraft’s builder Dave Lenart of Bethel, Vermont. Dave completed the build from a manufactured kit. An experienced builder and mechanic, Dave has built two prior Bearhawk aircraft including 4-Place and LSA models. He is currently assembling a Patrol.
Working closely with Bob Barrows, creator of the Bearhawk lineup, Dave incorporated a 180-hp Lycoming O-360 engine built by Bob into the first flying Companion. The aircraft features completely flush-riveted aluminum wings, a super strong steel tube fuselage, and an airfoil shaped empennage. The two-place Companion handles and performs much like the narrower Patrol. A slightly shorter fuselage makes it sportier than the “SUV/pickup” styled Bearhawk 4-Place.
The build was completed in 10 months and an estimated 1,000 hours—a short timeframe by most kit-built aircraft standards. The first Companion has accumulated 12 hours thus far in flight tests at held Lebanon Municipal Airport (KLEB), also confirming center of gravity loading.
According to Dave, “The shorter nose of the Companion makes taxi visibility very good. With full fuel of 50 gallons, the aircraft has proven very stable.” He noted that clean stall is at 42 knots indicated, and 38 knots with full flaps. The aircraft was engineered by Bob with STOL characteristics in mind. A Riblett airfoil gives the aircraft uncharacteristically higher cruise speeds than other aircraft of its class.
Commenting on the kit, “I see excellent quality welding, fit and finish of the tubular steel frame. Wings were delivered at an advanced stage of completion. Tanks were installed, wings were drilled with proper dihedral and angle of incidence. The wing struts were finished. Its tail surfaces were balanced.” Dave added, “The skylight formers and other improvements are nice updates to the older kits.” He estimated a savings of 100 hours or more from his earlier projects.
Buyers were clamoring for a side-by-side, two-place Bearhawk and the Companion delivered. The result is a very rugged utility plane with a large area for cargo. The model was introduced in August 2019, with first kit deliveries in January of 2020. Dave’s Companion came in at 1,130 lb empty weight and 2,200 lb gross. It spins a Catto 76×62 two-blade, composite cruise propeller.
Please price list bearhawk Quick kit . I am from Evrope.
Have nice day
Říha Vladimír – this time piper PA 28 OK-SDK
Here you go: https://bearhawkaircraft.com/bearhawk-companion/
