Design Process: Vertical Tail Spin Considerations
Not every airplane is designed to perform intentional spins, but that doesn’t mean the designer can safely ignore the effect of the vertical tail and rudder on the spin characteristics of the airplane. Light airplanes certified under U.S. FAR Part 23 must meet the following rule even if they will be placarded against intentional spinning … Continue reading Design Process: Vertical Tail Spin Considerations
