Design Process: End Plates and Winglets
A wing produces a pressure difference between its upper and lower surface. The pressure on top of the wing is lower than the pressure on bottom. At the wingtip, the wing disappears to the air, removing the barrier between the two pressure zones. Just inboard of the tip the wing deflects the air downward, while … Continue reading Design Process: End Plates and Winglets
