Cleco Card
If you are like most metal airplane builders, you probably have a couple of plastic cups or buckets full of Clecoes in your shop. Clecoes end up everywhere-on the workbench, in the back of tool drawers, under the workbench-and we rarely know how many we actually own. This is fine in most cases of aircraft fabrication-but when you get to closed-out structures or maintenance jobs, it is bad form to leave the little devils floating around inside an airplane.
shop tip 115
I recently saw a clever idea for keeping track of Clecoes while visiting the Voodoo Racing hangar at the Yolo County airport in California. It would be really bad to have a loose Cleco rattling around at 500 mph, so the guys in the shop made up these little “Cleco cards” to keep track of how many are accounted for. Easy to make, they might keep things more organized in the shop-for those who like to keep their Clecoes in a row.
Previous articlePathfinder ADS-B Receivers Now Compatible with FlyQ EFB
Next articleKitplanes Visits the Rotax Factory
