Clamp Stick
Every once in a while, there’s not really a good way to clamp a small fitting to the drill press. What I do is clamp a stick to it. That gives me sufficient leverage to hold the part steady while I drill it.
The only important factor is to be sure that the clamp can’t mar the part. I find a small piece of model airplane plywood works well to prevent the clamp from damaging the part.
Previous articleCruisin'
Next articleJake Hayes' CubCrafters EX
David Paule
David Paule retired after 30 years of structural analysis and is now building an RV-3B to keep from getting bored. The structural engineering included a mix of aircraft and spacecraft. He has been a private pilot since age 18 and currently owns and flies a Cessna 180.
