Many aircraft kits are designed around the use of blind rivets—also known as pulled rivets or “pop” rivets (POP rivet is a trademarked name). For Experimental aircraft, the blind rivet can give traditional solid riveting a run for the money. This is because if we compare the two riveting technologies (solid rivets versus blind rivets), … Continue reading Blind Rivets: Look Closely
