The Belite Digital LCD Altimeter / VSI is designed to provide many critical pieces of flight information to the pilot in a single, small lightweight enclosure. The unit is not TSO’d or PMA’d. Use only in appropriate aircraft as a backup to certified instruments in VFR conditions.
Features:
- Displays altitude in increments of 10 feet
- Displays Vertical Speed in increments of 10 feet
- Altitude and Vertical Speed are simultaneously viewable on home screen
- Weight of just 1.8 ounces (51 grams)
- Displays last set barometric pressure continuously
- Displays density altitude
- Displays pressure altitude
- Displays instrument (cockpit) temperature in Fahrenheit and Celsius
- Displays absolute pressure in inches or Kpa
- Displays system voltage
- User settable voltage alarm
- User settable metric (meters) or English (feet) display units
- User settable VFR cruising alarm — advises pilot when current altitude is more than 100 feet off a legal VFR altitude (1500, 2500, 3500, 4500 ft ASL…)
- Daylight readable LCD display, easy to read, dimmable
- Backlight may be turned on anytime from the front panel (external dimmer switch not required)
- Accepts external dimmer backlight input
- Very low power requirement — uses 10 milliamps (0.01A) of power in normal operation
- May be connected to ship’s static air pressure source
Use code DALT2015 when ordering.
