Bead Blast for Bond Prep
Surface preparation is easy if you have access to a bead blast cabinet.
Bonding to a glossy, fully-cured epoxy surface (the left side of the photo) will result in a weak joint. The usual method of surface preparation is to abrade the surface thoroughly using sandpaper prior to any bonding step.
Sanding works, but often requires cutting into the topmost fabric ply to really remove all the gloss. It is also dusty and slow, and it can be difficult to fully sand the surface down inside pits and opened blisters.
But there is another way.
Do you have access to a bead blast cabinet? The quick approach is to gently blast the surface. The glass beads evenly abrade every bit of the surface, including pits and voids (the right side of the photo), leaving it ready for bonding. Just blow off the dust and proceed with subsequent lamination or surface fill.
st 001
The glossy surface on the left is untouched, and will provide a poor bond. The right side has been bead blasted and will give a good grip.
DanHorton 100px 4 clearpixel 254
Dan Horton says he is “just a homebuilder”. He has been a pilot more than 30 years and currently flies a custom RV-8.
Previous article2014 Kit Aircraft Buyer’s Guide
Next articleBob Cartwright's RV-7
Dan Horton
Dan Horton has been crazy about airplanes since dope was a good thing. When not in the shop or researching some subject of interest, Dan can be found in his Van’s RV-8. He has been flying more than 40 years, and has not yet caused an international incident. That we are aware of, anyway.
