Yes, I believe it was a light single, a tail dragger. Spent at least a week sitting in the same spot at Oshkosh to make a depression that deep. Probably ended up sitting on its wheel pant. Part of a large flock, judging by the number of similar divots in the surrounding fields. I suspect that it was a gathering… possibly a convention! No sign of them now–no telling where they all went. But I bet they had a lot of fun while they were here.
Mel Asberry - 0
Recertifying a Homebuilt after major changes. Changing the gross weight when putting a Rans S6S on floats.
How to Calibrate Angle-of-Attack on Garmin’s G3X Touch System
For pilots who fly with modern electronic flight instruments, having access to accurate, repeatable...
Avoiding the Traps of Bad Engineering and Construction
There's a large body of knowledge of good engineering practice for aircraft. Most of this knowledge was gained the hard way, and it should not be ignored lightly.
