Does the latest LED technology beat up on the ancient 4509 landing light for Experimental aircraft? You bet it does. Here’s KITPLANES editor in chief Marc Cook for a look at the AeroLEDS Equinox PAR 36 landing light with both spot and wide (taxi) beam patterns.
Staying in the Game
It’s never been easy to afford flying, and it’s getting harder. As costs continue to rise, here are innovative ways to stay in the air.
Missing Rivets
This is the root rib on a horizontal stabilizer. The rivets that fasten the...
Airpark Living, Continued
Last month, I talked about the various types of airparks available for those so...
Engine-run Requirements for the DAR Inspection
Mel Asberry - 0
Do you need to run your engine for the DAR? How does using a certified engine and prop affect your Phase I test period? How about the gray areas regarding dual flight instruction? DAR Mel Asberry gives you the straight scoop.
I like the 4509. Works great. Lasts a long time, and it’s cheap. Those LED landing lights are big bucks. No way I’d pay for those. Fools game for minor differences. Actually at the airport when I see those LED ldg. lts. installed I laugh at yet another sucker who bought into the hyped up overpriced gimmick.
Maybe in your installation, but I’ve had very poor luck in the Glastar keeping the 4509 alive.
Cowling located incandescents often fail early due to engine & cowling vibration and ultimately inevitable normal filament thinning. Thus the filament becomes substantially more fragile with some hours of actual use.
Wing mounted they last far longer.
Depending on the offending harmonic vibration, orientation, up/down vs side to side, some users have found incandescents can last longer when the filament is oriented vertically, even though that’s not the ideal for beam angles. 4509 makes a wider beam in one axis than the other axis.
If using for daytime bird and collision avoidance benefits, which can often be a very high priority, both LED and HID are typically far better achoices especially for longevity, ie. “Murphy” etc.
I think the only advantage the 4509 has is price. LEDs are superior in every other metric. I am building an S-21 and it will have LEDS throughout. There is simply no reason to use incandescent lights unless you also need heat with your light.
