Carving Fiberglass the Easy Way
Shaping fiberglass parts might be messy, but it doesn’t need to be hard. When I need to cut back an edge, I find that an angle die grinder with a 2-inch sanding disk makes quick work of the task. The key is to anchor your hand to make it steady, and then take shallow cuts up to the pre-drawn line. To make a radiused corner, the edge of the disk makes a great carving tool—just take it slow and steady for a nice shape. Always wear a dust mask when grinding fiberglass.
fiberglass carving 001
Mark the lines for the cutout you want, then use a 2-inch sanding disk to carve the glass up to the line.
fiberglass carving 002
Radiused corners can be shaped by gently stroking the disk to create the curve you need. Steady the hands on the workpiece to make minute adjustments.
fiberglass carving 003
The edge of the disk is used to do precise cutting on the curve.
fiberglass carving 004
The finished cut can be touched up with a little sandpaper, and it is ready for paint.
Previous articleHomebuilts Well Represented at Pylon Racing School!
Next articleCubcrafters Announces Carbon Cub FX Builder Assist Program
