Dynamic propeller balancing can smooth out your ride and reduce wear and tear on engine parts. If you can find a mechanic with the right equipment, a dynamic prop balance should cost about $150. If you have some extra cash and would like to provide this service to others, you can buy a DynaVibe prop balancer for $1,495. They are available directly from DynaVibe through their web site or from Aircraft Spruce.
Tachometer sensor (yellow) and accelerometer shown in place on a Lycoming O-360 engine. You must fabricate your own simple brackets for the sensors to suit your engine.
The process of balancing a prop is pretty simple, and almost everyone agrees that it was worth it once it’s done. Reduced vibration greatly reduces problems with cracking baffles and spinner backing plates. It also helps to extend the life of engine accessories such as alternators, starters, and magnetos, not to mention exhaust systems. Anything that hangs off your engine will be happier with less vibration. Reduced vibration can also help reduce pilot fatigue on long flights and reduce vibration damage to avionics. Lastly, the propeller itself will benefit from reduced vibration, which is why all of the major propeller manufacturers recommend dynamic balancing.
When you run the engine up to cruise rpm, be sure to chock the wheels and point the nose into the wind.
Pre-Balancing Checks
Before you dynamically balance your prop, there are a few things you need to check. Does the propeller need repairs? Minor nicks and scratches should be corrected before balancing, and exposed surfaces should be repainted. If there is any major damage, the prop should be sent to a prop shop for repair. (See “Taking Care of Your Metal Prop,” February 2015, for more on prop repair.)
With nicks and scrapes properly treated, next check the track of the blades. Place an object behind one blade of the prop as it is pointed down, and move the object until it just barely touches the prop blade near the tip. Now rotate the prop until the other blade or blades just pass the same object. They should all be within 1/16-inch of the same spot as they pass by. It is usually easier to remove a spark plug from each cylinder when you do this so the engine can be turned over easily and not accidentally move the plane.
Other possible problems such as loose blades or leading edge protectors on wood props must be corrected before balancing. Lastly, be sure the spinner and backing plate are in good shape and free of cracks or missing screws. In other words, the prop needs to be in tip-top shape before any attempt is made to balance it. The engine also needs to be running smoothly. An engine with a fouled plug or a magneto in need of attention will not run smoothly enough to get a good balance readout.
It is best to have a helper handle the balancer unit while you handle the plane. The initial reading as shown came out to 0.21 in/sec2 and 29 degrees.
Balancing
Once you have determined that everything is in good shape firewall forward, remove the top engine cowl and follow the sensor installation instructions that come with the balancer. You may need to fabricate some simple brackets to hold the sensors if you are the first person to use the equipment or if you have a different type of engine. The brackets do not have to be elaborate at all. They just need to be sturdy. They should mount the sensors as close to the centerline of the engine as possible. The tachometer sensor must be positioned so that its light can shine on the prop or spinner backing plate.
With the sensors in place, check that the light from the tach sensor shines in a spot where you can place a strip of reflective tape that comes with the balancer. Usually the back side of a prop blade will work well. Before installing the reflective tape, check the position and aim of the tach sensor by turning the balancer on and letting it shine its laser light on a piece of white paper held near the prop. It will not be visible in bright sunlight, so you may need to shade it or move the plane into a hangar where the light can be dimmed. Once you have aimed the tach sensor, stick the tape where the light will shine on it. The accelerometer sensor requires no adjustment once it is properly and securely positioned. Just be sure that the wires protrude from the top of the sensor.
Mark the degrees with tape at the bolt hole nearest the indicated angle. Then rotate the engine until the hole opposite the one marked is accessible. Be sure to remove the tape.
With the sensors properly positioned, route the wires away from moving engine and prop parts, and away from hot exhaust pipes. The balancer readout will usually be best positioned in the cabin of the airplane. Ideally, one person will be operating the airplane and another will be handling the balancer readout, but it is possible for one person to do everything.
Position the plane so it is facing into the wind and, with all due caution, start the engine and warm it up to at least minimum full-power operating temperature as per the engine manufacturer’s recommendations. Be sure the brakes work well and the wheels are chocked. Run the engine up to cruise rpm—usually 2300 to 2500 rpm—and hold it there. Press the button on the balancer and wait for the reading to stabilize, which should take less than 10 seconds. Reduce power and repeat the process to confirm the initial reading. If the two readings are very close, shut the engine off and note the reading on the balancer.
If the readings are not close, try again until you get two readings in a row that are very close. If you can’t get the readings to stabilize, you will need to find out why. Problems could come from poorly mounted sensors, a poorly running engine, or a piece of reflective tape that is too short. Consult the DynaVibe manual for more troubleshooting ideas.
An AN4 bolt and two AN970 washers provided just the right amount of weight to bring the prop into balance.
Interpreting the Readings
Assuming all went well with the test, you will end up with three numbers. One is an acceleration in inches/second2 and the second is an angle in degrees. The balancer also gives a very accurate rpm reading to compare to your airplane’s tachometer. Accelerations can run from 1.25 or more on the high end—horrible—to 0.04 on the low end—perfect. With a reading of around 1.25 or more, you will need to have your propeller statically balanced by a prop shop before you can attempt to dynamically balance it. More typically a good but unbalanced prop will have an acceleration of 0.20 to 0.30. This is easily corrected.
Acceleration is caused by the centripetal force exerted by excess weight concentrated on some spot in a rotating object, in this case your propeller. This is the same phenomenon that you deal with when you get the tires balanced on your car. The prop balancing process is also similar in that weight will be added opposite the heavy spot to balance it out.
Affix a piece of reflective tape (provided with balancer) to the back side of a prop blade. The tape should be at least 1.5 to 2 inches long. Be sure it lines up with the tachometer sensor’s beam.
The final reading is the angle. The angle reading is the number of degrees in the direction of prop rotation from the white tape to the heavy spot. The balance point will then be opposite the heavy spot, or 180 degrees away. This is where weight will be added.
Here is an example: We tested my Sportsman with a Lycoming O-360 engine and a Hartzell constant-speed prop. The initial reading showed an acceleration of 0.21 and an angle of 29 degrees. The spot to add weight was thus at 29 plus 180 or 209 degrees. As luck would have it, the Lycoming ring gear carrier has holes evenly spaced around its perimeter every 30 degrees. I placed a piece of tape on the hole at 30 degrees and turned the engine over until I found the hole opposite the tape and added some weight in the form of an AN4 bolt and two AN970 washers. I held it all in place with an AN363 all-metal lock nut. As it turned out, this was exactly the right amount of weight to add. Master mechanic and airplane builder Jerry Scott, who graciously loaned me his prop balancer for this article, deserves the credit for the weight call. I probably would have needed to take an extra step or two to get to the correct weight without his experienced eye to help out. The retest yielded a result of 0.02 and 13 degrees, which, according to DynaVibe, is close enough to be called perfect.
If your first guess is not as close as mine, you will need to try a time or two by adding weight and retesting. If you add too much weight, you will see the angle change to something closer to where you added weight. Just remove some of the washers and try again. If the angle stays about the same and the acceleration decreases, but just not enough, add another washer and test again. Any acceleration reading below 0.07 is excellent and below 0.04 is perfect according to DynaVibe. If necessary you can use an AN3 bolt to save a bit of weight, but do not use stick-on weights. If you add weight to the spinner backing plate instead of the ring gear support, be sure to maintain proper edge distances with any holes you drill.
Replace the engine bolts and tighten them to the manufacturer’s recommended torque after you remove the sensors.
Wrapping It Up
When you are satisfied with your results, remove the sensors from the engine and replace the bolts. We used the small bolts that hold the case together on my Lycoming, which worked really well, but these bolts need to be retorqued to 75 inch-pounds after they are replaced. Also, be sure to use new internal star lock washers to keep the bolts tight. If you use other bolts or a different engine, be sure to consult the manufacturer’s literature for proper torque numbers. Reinstall the cowl, collect all your tools, making sure all are accounted for, and record your work in your logbook. Your prop should not need to be rebalanced unless you damage it and have to repair it, or if you repaint it.
Now go for a test flight and see how much smoother your engine feels.
