One important step in preparing any kit for its first flight is getting an accurate weight and balance report. To do that, it’s time to roll the plane up on a set of calibrated scales. In this video, Larry Anglisano along with Mark Welch put a ready-to-fly Van’s RV-10 on the scales to get some numbers.
Archive: January 2007
Our coverage for the 2006 Reno Air Races appeared in the January issue the...
Metal Magic: Cutting Round Instrument Holes
KITPLANES editor at large Paul Dye continues the Metal Magic series with a tutorial...
One Step Drill and Tap
We use quite a few small machine screws in our homebuilt projects. These small...
All About Avionics, Part 9
Stein Bruch - 0
One of the final steps in getting your avionics suite to work is installation of some sort of antenna to capture various radio frequencies. Failing to choose the right antenna and install it properly can compromise the whole installation. Rather than focusing on the intricacies of antenna design, the author discusses the merits of internal versus external for particular equipment plus where to place them; by Stein Bruch
Weighing an RV-10 without its gear leg and wheel fairings seems likely to create a very strong temptation to use that data for the completed aircraft. And a builder who records and remembers only that ‘lightest ever’ weighing result. The more commonly recommended — and more honest — real world approach is to add the fairings sitting loosely at their installed positions, along with other things such as carpeting, seats and seat backs, and have those be part of the empty weight.
The aircraft was weighed with everything that will be on and in the aircraft for its first flight, with a planned reweighing and revision when it’s fully assembled.
Maybe they left out leveling the airplane for simplicity’s sake but the numbers for each wheel won’t be correct and the CG will not be accurate until weighed when level. Or am I missing something?
I agree. My RV-14A is 3 deg nose up which means to me I need to have the mains about an inch above the nose when on the scales.
Also I did not understand the raising the nose 10” and how the weight would be measured, i.e. applying downward weight on the tail changes overall weight of the aircraft.. Did you place a block under the nose wheel?
What is the function of cg height?
Why was the plane not put in flight level position?
Thanks!
