Sometimes welding should be left to those more skilled in its practice. I don’t think I would trust this repair that was made to the rudder pedal bars in an RV.
Around the Patch
Editor-in-Chief Marc Cook discusses the mood at the annual AOPA gathering, where he found an upbeat vibe, cautious optimism about the FAAs pending homebuilding rules changes, and a positive announcement from Glasair Aviation.
Mini Satcoms
The short list includes considering how, where and why you’ll use the device, plus app interfaces and data costs. SPOT and Garmin are standouts.
“Booger weld”…
I would grind it down and break the plate off and reweld with a new bead. That looks like spot gas welding with a coat hanger. I would accept a brazing job on that but a good weld is preferred
Must have held the welding rod in his nostrils and the welder between his toes. Nice!
Its Mig welded very cold
I cannot believe that even the most inexperienced builder could not recognise a dangerous weld when they see one.
Here a weld like that is known as “Spoggy Shit” (Spoggy – a small Australian bird)
I agree with Bruce. Grind it all off and get an experienced welder to reweld it.
Grinder and paint makes me the welder I ain’t….. lucky they didn’t try to ‘pretty up’ this mess with Bondo
My daddy says if you gotta grind every weld to make it look right., your not a welder your a grinder😂
