Tailwheels and their associated linkage should be carefully preflighted. Here’s a partially broken tailwheel chain link that has the potential to cause a complete loss of ground control when it totally fails.
How Fast Is a Speed Nut?
A “speed nut” is a somewhat generic term that is occasionally used for a...
Commander Klutz and the Lost Planet Airmen
Tom Wilson - 9
It’s a fair assumption most KITPLANES® readers were not big on essay writing in...
Design Process: Wing Structure
Last month we started our discussion of wing design with a look at the...
Learning To Weld
Ken Scott finds that practice makes perfect (or pretty good) as he puts his newfound wire-feed welding skills to the task of replacing rotting wood hangar doors with sturdy, steel-frame ones.
