Some gascolators have internal O-rings that should be checked for deformation regularly. This was caught on an inspection, but the gascolator had blue telltale signs of leakage that had been happening for some time. A leak in your gascolator may cause fuel stoppage to the engine due to the pump sucking air.
On the Level
A few months back in this very column, I suggested that pilots should keep...
Aero ‘lectrics
Heat and avionics don't get along all that well. Rather than installing a fan that runs all the time, Jim Weir suggests building and using a fan that runs only when you need it.
