Many times starting problems can be traced to spark plugs with high resistance. The high resistance of the plug can make it very difficult for the magneto to fire a spark, especially at lower starting rpm. Long-term wear of the magneto points can become a problem as well. The plugs should be checked at the annual condition inspection, every 100 hours, or whenever starting problems are noted. Tempest makes a really nice go/no-go tester, but you can use a normal ohmmeter as well. Resistance should be less than 2K ohms when tested across the center electrode. Most new plugs will indicate around 800-1200 ohms.
Clean Oil Makes for a Happy Engine
Dave Prizio - 4
You can do two things that will extend your engine’s life more than any...
Around the Patch
The Editor-in-Chief discusses how the improper cut of his instrument panel affected the performance of his Dynon autopilot; by Marc Cook.
Dimpling for Beauty and Speed
Each time you install a fastener on your airplane kit, consider whether the head...
Mel Asberry - 0
Does an A&P have to sign off on an ELT inspection? And can a Sport Pilot fly a Cessna 172?
