Sonex Aircraft announced the development of a 2-place variant of the SubSonex Personal Jet today. SubSonex JSX-2T is designed to be the lowest cost jet trainer and a perfect transition trainer for the single-place JSX-2, and for those who want to share the unique experience of jet-powered flight in a light aircraft.
JSX-2T is configured with side-by-side seating for optimum flexibility in CG/loading and offers an ideal training environment for its crew. With a wing span of 21.8 feet JSX-2T will have similar wing loading and handling to the single-place JSX-2. The two-place jet will utilize the same proven PBS TJ-100 turbojet engine system. An optional, more powerful PBS TJ-150 will achieve even higher performance.
The company will hold an Open House and Homecoming Fly-In event on Sunday, July 21st at 10am where visitors can learn more about the JSX-2T and its projected development timeline. The event is held at Sonex Factory Headquarters on Wittman Regional Airport the day before EAA AirVenture Oshkosh 2019 begins. A forum will also be held at AirVenture on Wednesday, July 24th on Forum Stage 5 at 11:30am.
JSX-2T Estimated Specifications and Performance
Length | 18′ 7.75″ [5.68 m] |
Wingspan | 21′ 9.6″ [6.65 m] |
Wing Area | 87.2 sq ft [8.1 sq m] |
Height | 5′ 8.2″ [1.73 m] |
Width with Outboard Wing Panels Removed | 7′ 6″ [2.29 m] |
Cabin Width | 42″ [106.68 cm] |
Empty Weight (estimated) | 530 lb [240.4 kg] |
Gross Weight | 1500 lb [680.39 kg] |
Useful Load (estimated) | 970 lb [440 kg] |
Fuel Capacity | 50 U.S. Gallons [189.3 l] |
Baggage Capacity | 40 lb [18.14 kg] |
Stall Speed (estimated) | 65 mph [104.6 km/h] |
Cruise Speed (estimated) | 200+ mph [321.9+ km/h] |
Never Exceed Speed | 275 mph [442.6 km/h] |
Load Factors (Utility) | +4.4 Gs, -2.2 Gs |
Load Factors (Aerobatic) | +6 Gs, -3 Gs |
Visit Sonex on the web: www.sonexaircraft.com
